1. The HTF Tapatalk application has been discontinued. Please see the thread in the Forum Help & Feedback area for more information.
which amp for passive subwoofer
Discussion in 'Speakers' started by Sam Robertson, Aug 16, 2004.
  1. Sam Robertson
    Sam Robertson Stunt Coordinator
    Jul 10, 2004
    68
    if one was to purchase an svs passive subwoofer, can someone recommend an amp (other than the ones listed on the svs website)
    thx
    sam
  2. Dave Moritz
    Dave Moritz Producer
    Jul 7, 2001
    5,590
    487
    California
    Dave Moritz
    Depends on your budget and what level of equipment you are shooting for? And how much power is recomended for the SVS? Adcom makes a nice beefy amp for the money with a toridal transformer, and there is also Rotel. If you want something that is really got guts and something you can use for uping the anty on your system. I would recomend the CineNova Earthquake amp (www.earthquakesound.com). It would be more helpful if you could let us know what the power handling is on that SVS and what your budget is [​IMG]
  3. Edward J M
    Edward J M Cinematographer
    Sep 22, 2002
    2,031
    http://www.poweralley.com/rmx850.htm
    300 watts per channel into 4 ohms (perfect for dual CS), or bridged one channel at 850 watts into 4 ohms (a bit much for a CS-Plus or Ultra, but just calibrate and use common sense).
  4. Sam Robertson
    Jul 10, 2004
    68
    i only want to spend like < 200 on it.
  5. ross ish
    ross ish Stunt Coordinator
    Nov 18, 2002
    163
    With that kind of budget i would look at Rythmik Audio plate amp (350watts)or the Fidek pro amp (300wpc)at mcm electronics.
  6. SteveCallas
    SteveCallas Second Unit
    Dec 23, 2003
    475
    Less than $200? That means you'll have to look at used stuff, but either way, I would definitely go with a pro amp, NOT a home audio amp. Crown XLS series should be a nice fit.
  7. TimRP
    TimRP Stunt Coordinator
    Feb 9, 2004
    115
    If you really need something that cheap, I second the Crown XLS suggestion. A XLS 202 bridged would give you 500w into 4ohms, thats a lot of power, prolly more that you need, but headroom is always a good thing.
