Which 50" Panasonic Plasma? Help!
Discussion in 'Displays' started by Bob Keenan, Oct 26, 2005.
  1. Bob Keenan
    Bob Keenan Auditioning
    Aug 31, 2005
    3
    OK.... Tomorrow I order the 50" plasma tv online.
    I had a a good home theater sound system. I am getting a dish network HDTV DVR (its does not have HDMI but does have RGB component). The DVD player has HDMI. So I don't think I need speakers or any HD stuff on the plasma.... right?
    After reading the forums and reviews I have it down to the Panasonic TH50PHD7UY (discontinued but still in stock), TH50PHD8UK (replaces the previous unit), and the TH50 PX50U (the commercial version). The prices are all within a few hundred dollars with the 7UY the cheaper and then the 8UK and finally the PX50U.
    From reading the specs I don't see a big difference??? The 8UK shows more billions of colors than the billions in the 7UY but will I be able to tell the difference.
    So any help out there???
    I am leaning toward getting the best deal on the discontinued 7UY. Any thoughts on that??
    Bob Keenan
  2. DougRuss
    DougRuss Stunt Coordinator
    Oct 3, 2001
    195
    Not to steer you away from this Forum, but have you checked here for Help ?
    AVS Forums
  3. Mort Corey
    Mort Corey Supporting Actor
    Nov 21, 2003
    981
    The commercial displays don't come with an HDMI input for your DVD player so you might want to order that blade at the same time.
    Mort
