Where to set subwoofer level: prepro vs sub
Discussion in 'Archived Threads 2001-2004' started by FredS, Jun 21, 2002.
  1. FredS
    FredS Extra
    Jan 4, 2002
    19
    On most preamps you can change the level of the sub-out, and on any powered subwoofer you can adjust the volume at the sub. I have set my preamp to the minimum subwoofer level, based on the assumption that I might as well make the internal amp in the sub do all the work. It sounds fine, but I wonder what other people do, and what their rationale is. Also, is there any technical reason why it should matter?
  2. Michael Lomker
    Michael Lomker Stunt Coordinator
    May 17, 2002
    164
    The internal amp in the sub does all of the work, anyway. The pre-pro setting only adjusts the voltage on the RCA cable going to your powered sub.
    What they usually recommend is that you set your pre-pro at about 1/3 of the available range and adjust the sub control until it is loud enough. If you are exceeding 3/4 on the subs volume control then you should start turning up the pre-pro. At some point the sub will start to distort, though....you probably need a bigger sub if 1/2 on the pre-pro and 3/4 on the sub isn't adequate.
