Where to place in-wall subs?
Discussion in 'Home Theater Projects' started by Philip Hamm, Oct 14, 2003.
  1. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Here's my room:
    [​IMG]
    Ignore the patio door, it's elsewhere in the basement.
    Where do you think I should put two in-wall subs? The bottom of the picture is where the screen is going to be. I was thinking of putting the subs on the right hand wall in the rear of the room one right on top of the other. They can only go on the side and back walls.
  2. MichaelDDD
    MichaelDDD Supporting Actor
    Sep 29, 2003
    616
    Mike
    I just have to say this.
    37' x 21' was about the size of my first APARTMENT. A one-room studio in NYC. That is all.
    I wish you luck w/your quest. And I wish ME luck that someday, I can afford a house of gargantuan proportions that would allow me a football stadium-sized room like yours to play with. [​IMG]
    Good luck, Philip. [​IMG]
  3. Philip Hamm
    Jan 23, 1999
    6,873
    2
    Well, that's not the size of that part of the basement, that's the size of the L-shaped room. [​IMG] The fact that it's "L" shaped means it's smaller than those dimentions suggest. It's still a huge room.
  4. MichaelDDD
    Sep 29, 2003
    616
    Mike
    That's OK...I can live with it...when can I move in? [​IMG]
    Why are you putting the subs in-wall? Do you not want the cabinets in the way? I guess you're going for a "stealth" home theater?
