Where to find 4mm machine screws
Discussion in 'Home Theater Projects' started by Jim Mcc, Sep 9, 2004.
  1. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    I am building a DIY ceiling mount for my X1, and I need to find 4mm machine screws 3-4" long. Any ideas, I tried Home Depot & Ace Hardware. Thanks.
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
  3. Bryan Michael
    Bryan Michael Supporting Actor
    Mar 2, 2002
    564
    i had to go to a local hone shop to get my 4m screws
  4. MikaelO
    MikaelO Auditioning
    Jan 6, 2004
    8
    I got mine in HD or Lowes.. don't remember which, but the longest ones they had where 20mm. My projector (Benq DX650) is mounted on a piece of 3/4" MDF so together with the space made by the rubber feet, I had to sink the screws pretty far into the MDF.
  5. Jonathan Smith
    Jonathan Smith Stunt Coordinator
    May 26, 2002
    122
    My local Lowe's had the 4mm screws in 10, 15, 20, 25, and 30 mm lengths.
  6. Todd Shore
    Todd Shore Stunt Coordinator
    Jun 5, 2001
    101
    If these are for screwing into the mount holes on the X1 it will take #6's.
