Where to buy speaker spikes in Canada?
Discussion in 'Archived Threads 2001-2004' started by Calvin_Y, Jan 15, 2003.
  1. Calvin_Y
    Calvin_Y Auditioning
    Jan 15, 2003
    2
    Hello All,
    I'm in the process of building my own speaker stands. I've based my stands on the Wood Tech, Hardwood series.
    At first I was going to order spikes from partsexpress, but they charge international shipping prices to Canada ($17 US for $5 worth of product).
    Thus I'm looking for options that are either local (Toronto), in the country, or have reasonable shipping rates from the States.
    Thanks for you help,
    Cal
  2. AllanRW
    AllanRW Second Unit
    Nov 30, 2001
    342
    Bob at CSS has them.
  3. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    I read somewhere where someone went to a local hunting and
    sporting goods shop and purchased Broad Head Arrow Points
    for archery, they come with Aluminum Knocks that you can
    glue and press into the wood and then screw the broad head
    points into the knocks. They cost something like $3.00 per
    6 broad heads or something cheap like that, and they are
    steel.
  4. Chris Carswell
    Chris Carswell Supporting Actor
    Mar 5, 2002
    598
    That was Ronnie. I went even cheaper [​IMG] . You can get the points at Walmart, 12 for $1.5 ain't bad at all [​IMG] They do have Walmarts in Canada don't they???????????????
  5. Owen Bartley
    Owen Bartley Second Unit
    Nov 11, 2002
    487
    Dude, at this point they probably have WalMarts in Siberia. [​IMG]
  6. Calvin_Y
    Jan 15, 2003
    2
    Thanks for all the replies. I've also have found a great, cheap alternative for speaker spikes.
    I bought threaded inserts, nuts, and hanger bolts. The hanger bolts are the spikes. Hanger bolts have machine threads on the top half of the bolt, and a screw threads on the bottom. The screw side of the bolt will be my spike. Total cost from Home Depot, $5 Cdn.
  7. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    I used the archery points for my subs and they work great
