where to buy "cheap" headphone amp?
Discussion in 'Archived Threads 2001-2004' started by Kevin T, Feb 18, 2002.
  1. Kevin T
    Kevin T Screenwriter
    Jul 12, 2001
    1,402
    since i'm considering the 950 which doesn't have a headphone output i need to find a headphone amp. i've seen models from creek and musical fidelity ranging from $200-$400. however, the only time i use headphones is for late night television / movie watching where i'm not particularly concerned about quality per se but rather keeping the noise down so the s.o. can sleep. can anyone recommend a headphone amp that's not utter crap in the sub $100 price range?
    kevin t
  2. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    From my looking, no such thing. There was the HeadRoom AirHead which was priced at $100, but it would only run off of batteries. Now the cheapest HeadRoom lists is the Total AirHead at $160USD.
    http://www.headphone.com/layout.php?...tID=0010010005
    The cheapest other option I've heard of is the Meier Audio Porta Corda. Also $160USD. However this one is supposed to have a decent crosstalk circuit and you don't have to run it from batteries.
    http://home.t-online.de/home/meier-audio/portacorda.htm
    The only other option I'm aware of is this. What follows is a quote from John Morris's reply to one of my earlier threads on this topic.
  3. John Morris
    John Morris Guest
  4. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
    If you don't mind the "pro" look, check out the Behringer PowerPlay Pro headphone distribution amp. It has 3 headphone outputs, and it sounds great! (I don't own it, but I use it on a regular basis for mixing music, etc.)
    Certainly better than something like that Sennheiser unit.
    http://www.musiciansfriend.com/srs7/...nger+headphone
  5. JimN
    JimN Stunt Coordinator
    Feb 12, 2002
    81
    I would suggest the Creek OBH-11, It is a very neutral amp. For more info check out the forums at Head-Fi.
  6. Jeff_Hunt
    Jeff_Hunt Stunt Coordinator
    Mar 21, 2000
    57
