jimFred
- Dec 15, 2004
ok, i'm sort of new to all this so i need some advice before buying hookup cables...i bought a 42" sony plasma hd ready tv and am using a high definition cable box with component outputs and a dvi-d output..the tv has a dvi input....should i use a dvi cable as opposed to the component hookups?..is so, is there a difference beteween dvi-d and dvi?...also, what is a good quality cable at a fairly reasonable price?....i have some acoustic research master series cables from the dvd player to the tv, they seem good....
i also have to run some video audio cables....any suggestions as to brand?...would you go with monster cables or the master series from acoustic research or another brand?...and where is the best place to buy them?...thanks a bunch, this is a great forum
