Where is the best place to mount Bass Shakers in a Sofa?
Discussion in 'Archived Threads 2001-2004' started by jeff lam, Nov 2, 2001.
  1. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    I just picked up a pair of Shakers and want to know for all you experience ones out there the best place/area in the couch/sofa to mount them. Bottom? Back? Sides? etc...
    Also, everyone keeps saying, "When properly configured, they are an excellent addition to your H/T". Is there a special way to wire/configure them? I just assumed you hooked up the two terminals + and - to your amp just as you would a normal speaker. Any help would be appreciated.
    Thanks in advance!
  2. Gary Thomas
    Gary Thomas Second Unit
    Jan 17, 1999
    389
    I've got mine hooked up to the frame of the couch..on both sides. I'm not sure placement is critical, just space them out a bit. Another suggestion is that if your shakers can't be mounted on the frame due to the frame being too small, then mount the shakers to a square of particle board, then mount the particle board to the frame. (use particle board because a hard wood may split)
    I've got mine hooked in series, resulting in an 8 ohms connection. In other words, the positive wire goes to shaker 1, then the negative shaker 1 goes to positive shaker 2, then negative shaker 2 goes back to the amp.
    As far as being "properly configured," I believe most people are talking about the following:
    1. Feed your sub-out line from your receiver to the amp (or receiver)that will drive your shakers.
    2. Keep the volume level reasonable, so it enhances rather than dominates. You don't want to feel the shakers during dialogue.
    3. Enjoy!
    HT Pic's
  3. Jerold Burrow
    Jerold Burrow Auditioning
    Aug 5, 2001
    10
    Hi Jeff -
    I'd like to add that my bass shakers (Aura 25 watt) seemed to perform better when mounted vertically... so they shake the sofa up and down instead of side to side.
    Have fun with your setup...
    Jerold Burrow
  4. John H
    John H Second Unit
    Nov 27, 1998
    472
  5. jeff lam
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    OK, a couple more questions regarding the shakers. I have 2 Aura Pro (50W) versions and want to know what guage speaker wire will be sufficient to use for a 30ft run. Also, how would you split the LFE out? Will I need 3 Y splitters to make 4 outputs? 2 for the sub and two for the shakers? Is there a less expensive/easier way to split the signal?
    Thanks in advance!
  6. Gary Thomas
    Jan 17, 1999
    389
    Assuming you have 1 "sub out" line on your main receiver, you will use a regular splitter (1 to 2) with one line going directly to your sub and one line going to a "line in" on the amp or receiver that will power your shakers. I don't think the type of speaker wire is critical...though you may find others who disagree. I'd go with 18gauge for ease of running around baseboards.
  7. Justin Lane
    Justin Lane Cinematographer
    Jan 18, 2000
    2,149
    110
    Because the couch I have mine mounted to is a pullout, I decided to place them on the front of the couch. This seems to work very well. If the shakers were mounted right beneath the seating area, I think they could become a bit annoying at times.
    As for speaker wire, I am just using cheap 16 ga cable without any problems.
    J
