Tim Kline
- Oct 1, 2000
- Tim Kline
First, lemmie describe my room .... My TV room is about 11x15 .. one of the 11' walls is covered with shelves end to end with a big closet door in the middle.. the other has a door to the outside toward the end of it.. one of the long walls has a large pictre window off-center.. I have a 5" long corner computer desk along this wall, the sofa right next to it (under the window), and the TV directly across from the sofa, kinda in the middle but not quite.
So anyway, I'm wondering where I have to put my small speakers for the best sound. Right now, they're up in the corners of the room, but the TV/sofa isn't in the center of the wall and sometimes the sound is unbalanced (even when I adjust the balance) .. and a lot of times I just can't hear the corner speakers.. the way the room is, it's impossible to have the back speakers behind me, they're on the wall pointing down at the sofa..
Anyway.. would it be better if I got those tall speaker stands and put one each next to the tv on each side (or used the wall mounts I have and mounted them on the wall, right next to the tv), and the back 2 on stands/mounts right next to the sofa, and facing it (I don't wanna have a sudden loud back channel sound blasting right in my ear though )
For teeny speakers, are they better off mounted up in the corner of the room, or would those stands/remounting work better? Any ideas?
Here's a link to my reciever/speaker package so you can see how small the speakers are.. http://64.14.37.123/browser/index.html .. it's just those corner ones that I'm trying to find out the best way to put them...
