Where can I purchase blue LED???
Discussion in 'Archived Threads 2001-2004' started by rodneyH, Mar 17, 2002.
  1. rodneyH
    rodneyH Supporting Actor
    May 22, 2001
    844
    I am looking for a blue 5mm wide LED for a project, it needs to beable to opperate on 2 V, RS and PE don't have them, they all seem to require 3.5-5 v and don't work (i tried). Any ideas???
    Thanx
  2. Bryan Michael
    Bryan Michael Supporting Actor
    Mar 2, 2002
    564
    if you need 2 v to power the led just take the 2 v and run it to a relay that switches the 3.5-5 v then that would work you can get a relay for a couple of bucks and the power suply should be like 10 depends on how mych curent draw you need
  3. rodneyH
    May 22, 2001
    844
    bryan, that configuration will not work, it would just be much easier to buy a 2v that works, or give up trying to find a blue one and get another color, BUT my goal is to find blue.
  4. Ellen
    Ellen Stunt Coordinator
    Jan 8, 2000
    142
    Ellen
  5. DanWiggins
    DanWiggins Second Unit
    Aug 15, 1999
    324
    A 2V blue LED? To the best of my knowledge, you're not going to be able to find one. The technology that created the blue LED requires 3.2+ VDC. You'll need to make either a voltage doubler, or drive the base of a transistor to switch on a higher voltage.
    Dan Wiggins
    Adire Audio
  6. rodneyH
    May 22, 2001
    844
    Dan, thanx for the reply, I found a 2.5v would that be enough (in other words would it just light up a little dim) or will it not turn on at all, like the 3.5v i got
  7. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    Rodney,
    I was looking trough the PE catalog last night and found some lamp covers:
    http://www.partsexpress.com/pe/showd..._ID=1330&DID=7
    Not sure if they will work for your application but it seems like a way to go if you don't mind using a nylon cover.
    You will also have to find the right size as PE has many sizes of these.
    Good Luck!
  8. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    Why don't you just go to your local Radio Shack? They sell them.
  9. rodneyH
    May 22, 2001
    844
    the covers could be a good idea, thanks
    Thomas, I bought 1 from RS but they only carry 2 and they require more Volts, they don't work
