Where can I buy DVD cases?
Discussion in 'DVD' started by Mike V, Jul 16, 2004.
  1. Mike V
    Mike V Stunt Coordinator
    Jul 26, 2000
    87
    I am looking for a place to buy single DVD cases. I have seen them all over eBay and a couple other places online but they all seem expensive, $40. plus per 100. Has anyone found a source that they would be willing to share? I am also looking for the blank Title inserts which I cannot find anywhere.
  2. Garrett Lundy
    Garrett Lundy Producer
    Mar 5, 2002
    3,764
    www.inetdvd.com has single cases. Look under DVD/Media
    I don't know what you mean by blank title insert.
  3. Jeff
    Jeff Supporting Actor
    Jun 30, 1997
    947
    I think you'll get more responses in the DVD forum.
  4. Kyle McKnight
    Kyle McKnight Cinematographer
    Mar 8, 2001
    2,504
    I'd suggest a search. This topic has been discussed a lot.
  5. Mick B
    Mick B Stunt Coordinator
    Feb 29, 2000
    53
  6. Dave Farley
    Dave Farley Second Unit
    May 15, 2004
    412
    2
    http://www.sleevetown.com
    They carry the Amaray single and single-width double cases if you're particular about that sort of thing.
  7. nolesrule
    nolesrule Producer
    Aug 6, 2001
    3,084
    Clearwater, FL
    Joe Kauffman
    After shipping, US Plastic is probably the least expensive. That's where I bought my ThinPaks.
  8. Jonathan Carter
    Jonathan Carter Supporting Actor
    Jul 7, 2003
    535
    Or you can just go to a staples or some other office supply store, even target has them. They usually run about $6-7 for a 10 pack of cases. It is more expensive but much easier to go get without the wait. If you need 100s though, online would be the way to go.
  9. DouglasRobert
    DouglasRobert Second Unit
    Sep 12, 2003
    269
    If you're looking just to buy just a few at a time, then I would suggest you check out your local department store in their electronics department. They are usually buy the blank VHS tapes and/or DVD Recordable discs. Maybe Radio Shack will have them too.
    At Meijr, they had a multi-pack of cases that can hold 2 discs per case, so if you have 2 disc sets, you can put them in these thinner cases. I think they sell for around $5.00 for either 4 or 5.
