Josh Wolfman
- Dec 19, 2002
I would like a cd of tones from say 15 Hz all the way up. Where can I find this? Can I fins it on the internet and burn it onto a cd? Thx.
Do you think this is the limit on my sub or is there anyway that I'm losing something in sending this signal from my PC to my receiver?Nope. You get roll-off as the frequency INCREASES, not decreases. So it's not the connection.
Do you have your sub in a corner? You get a LOT of sound from nearby wall reflections so putting the sub in the corner of the 2 longest, un-broken walls tends to give you all that surface area to bounce sound off of. This also gives you "spikes" in your rooms response, but sometimes that is what you want.
