I have a Tosh TW40X81 shouldn't the screen be filled in normal mode when watching true HD seeing how it is broadcast in 16x9? Which mode do you leave the Tosh in? Full?
When you have the 6000 set to HD mode, you can have your Tosh set to anything you want because the 6000 controls the aspect ratio not your set..Your set can not control aspect ratio on a 1080i input..
For True HD, your 6000 should be set to normal.....When HBO HD or showtime HD is just transmitting 4.3 programming thru there 1080i hd channel you can use any of the 6000 stretch mode if you choose to fill the screen...
