Shawn Solar
- May 12, 2001
Do you have to compensate for dual voice coils. If say you have dual 2 ohm coils would the T/S change whether it were series or parallel? For instance QTS, QMS and QES change in regards to the resistance? any formulas? thanks.
I ask cause I'm working on a sub project with a friend(spl monster) using a driver with these parameters:
RFR3115
FS-22hz
DC-resistance-2x2.16ohms
QTS-.388
QES-.41
QMS-5.837
SD-860cm^2
VAS-98L
Moving Mass-384g
CMS-1.28E-04 m/N
Voice Coil Inductance-1.74mH
BL-12.85Tm
XMAX-19mm
SPL-88db
Pmax-1000watts
We are devising a plan on using a slot port for tuned to 35hz in a 21cuft enclosure using 4 drivers wired in voice coils in series and two woofers series then at the amp the 2 pair is wired in parallel for 4ohms. Then we may be making a baffle with a set of ports that can be tuned lower for SQ. They will fit through and cover the slot port with some sort of mounting system.
RFR3115
FS-22hz
QTS-.388
QES-.41
QMS-5.837
SD-860cm^2
VAS-98L
Moving Mass-384g
CMS-1.28E-04 m/N
BL-12.85Tm
XMAX-19mm
SPL-88db
Pmax-1000watts
