When taking Sub frequency readings do I just run the subs?
Discussion in 'Archived Threads 2001-2004' started by Steve Morgan, Nov 17, 2001.
  1. Steve Morgan
    Steve Morgan Second Unit
    Nov 10, 1999
    328
    110
    Farm in Kansas
    Steve
    I am hooking up my BFD and am taking my readings with the B&K Ref 30 tone generator and the RS spl meter.do I just have the sub that I am reading on or can I leave the mains on to?
  2. Guy Kuo
    Guy Kuo Supporting Actor
    Mar 6, 1999
    581
    It is a lot easier to understand what is going on if you disconnect your mains temporarily when first adjusting the sub with the EQ. After you have more comfort using the EQ you can go back and slightly retweak with the mains on. The problem with running the mains at the same time is that there will be peaks and valleys from the mains which obscure the subwoofer's response curve. That makes it tough to see where the parametric is having its effect - like fine tuning an instrument while a bunch of people are yelling. Ultimately, you do want to take into account the output of the mains, but start simple.
    I very strongly suggest a program like ETF (www.etfacoustic.com) or SpectraPlus (www.spectraplus.com) for doing this type of work. Yes, it some cash, but ETF will do hours of work in seconds and let you concentrate more time with trying for better results instead of tedious, slow measurements.
    Guy Kuo
    Ovation Software, The Calibration Tool Source
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,337
    99
    9,110
    Corpus Christi, TX
    Wayne
    For the way your system is configured (mono sub send split to two subs) take the readings with each sub individually, with the mains off. After both subs have been equalized, you can turn on the mains. Then you will need to blend them with the mains, that is, turning them both up or down. At that point it might be necessary to tweak the EQ in the crossover region for a proper blend, but that usually isn’t needed.
    Wayne A. Pflughaupt
    My Equipment List
  4. Steve Morgan
    Nov 10, 1999
    328
    110
    Farm in Kansas
    Steve
    Guy I don't have a laptop or a mich.I don't mind spending the $ but how do I get the mich or RS spl meter to the listening position with my computer in another room.I guess it would take a 20ft. cable. If you can tell me how I will purchase this software.
    Thanks Steve
  5. Guy Kuo
    Mar 6, 1999
    581
    I dragged my PC to the video room. A bit of work, but much cheaper than getting another machine. I have a laptop, but it is a Mac and the programs only run on PC's.
    Guy Kuo
  6. LeungNing Chu
    LeungNing Chu Auditioning
    Nov 16, 2001
    4
    Guy,
    I used ETF5 to get a low frequency plot of my room response, but after the burst signal, the plotted graph is always changing. I cannot get a constant pattern to see the peaks and lows. Is there any special timing parameter I need to use or procedure I need to follow?
    L. N. Chu
  7. Guy Kuo
    Mar 6, 1999
    581
    I used the default timing windows. Did you first do the loop back tests to make sure there aren't any oddities with your sound card's inputs and outputs? I found a big problem with my card's sound mixer and had to disable it to get a clean result during loop back.
    The mic must also be mounted, not handheld, to get consistent readings. Hand motion of the mic would throw things off.
    Guy Kuo
  8. John Morris
    John Morris Guest
    Steve: I did things a bit differently than others who posted here. I run my fronts at full plus LFE and my 4 surrounds at small so I decided to EQ for room effect only. So, I Spectraplus calibrated with all speakers driven, including subwoofer, and then used the graph to EQ my subwoofer output. This mostly involved reducing my subs output from 40-55Hz. I figured that in modes where I would have my sub active (movies), I would want to EQ for what I would hear and not what each speakers would output. Since then, I've added a multichannel SACD player. NOW, EQing with all channels driven is even more important... IMO.
    Take Care,
    merc
    [​IMG]
    God Bless America!!!
  9. LeungNing Chu
    Nov 16, 2001
    4
    Guy, Thanks for the info.
    My soundcard Maudio 24/96 runs the loopback test pretty well. I may need a tripod for my RS SPL meter.
    L. N. Chu
  10. BruceD
    BruceD Screenwriter
    Apr 12, 1999
    1,220
    If you don't have the ETF5 (what I use and prefer) or SpectraPlus, then just using an RS SPL meter and various source signals is possible. You could probably use a low-loss RCA cable from the ETF calibrated mic preamp to your PC and from your PC to your amp (for
