When is a sub boomy?
Discussion in 'Speakers' started by Ken.L, Mar 26, 2004.
  1. Ken.L
    Ken.L Stunt Coordinator
    Jan 7, 2004
    58
    How can I tell if my sub is boomy or not? I'm not sure what is meant by boomy. So, if anyone can describe how to tell if a sub is sounding good or bad, I would really appreciate it.
  2. John F. Palacio
    John F. Palacio Supporting Actor
    Jan 6, 2002
    575
    I'll give it a shot:
    Boomy normally refers to a "one note" quality in the sound. This means that a narrow band of frequencies is emphasized over the rest, therefore the term "one note".
    This is generally caused by the room and or placement of the sub, although a poorly designed sub can have a boomy quality by having a peak in a particular part of the spectrum.
    If, while listening to a recording, you hear a certain group of notes considerably louder than others, you have a boomy setup.
  3. Craig Chase
    Craig Chase Gear Guru
    Oct 21, 2002
    1,610
    45
    Pennsylvania
    Craig
    You can be certain a subwoofer is boomy if:
    Marko calibrated it for you...[​IMG]
  4. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Does it sound *real* or does it sound like your car does when you turn it up loud/ or a club.
    Flat bass is few and far between.
