when doing separates......
Discussion in 'AV Receivers' started by Phil_M, Mar 30, 2004.
  1. Phil_M
    Phil_M Extra
    Mar 18, 2004
    21
    how is the surround format handled? Is there a tuner or something out there that handles stuff like dolby, dds....or whatever the formats are?
  2. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    The processors in them handle it. There are dedicated processors for these discreet formats.
  3. Phil_M
    Phil_M Extra
    Mar 18, 2004
    21
    I was looking at a Carver.....and I did not notice a sub out...but just 5 channel outs....which makes snnse since most subs have their own power..but...
    How do you hook up a sub then??
  4. chung_sotheby
    chung_sotheby Supporting Actor
    Apr 8, 2002
    857
    Phil, when you say 5 channel outs, do you mean the speaker outs or the pre-outs? If you do not know the difference between these two terms, then I think it might be best for you to read up in the beginners section of this forum just to get a grasp of the types of terminology you might need to know when dealing with home theater audio/video
  5. Phil_M
    Phil_M Extra
    Mar 18, 2004
    21
    Oppps! Yeah you are right. I forgot that you need a preamp and an amp. This one is an amp to supply the speakers. The preamp would be the unit that has the "pre" to the self powered sub. Sorry man.....I've just been working to many other angles these days to remember. So the preamp would be the unit that figures out the dolby, dds, etc. right?
  6. ScottCHI
    ScottCHI Screenwriter
    Feb 21, 2004
    1,292
    exactly. a dd/dts receiver with pre-outs can do it too.
  7. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Phil, it sounds to me like you are confused?
    A seperates setup has a preamp/processor with *NO* amplified outputs, and will have line-level RCA outputs to drive all the separate amplifiers.
    A receiver, on the other hand, is both the processor and amplifiers all together in one unit (along with a radio tuner). This will have amplified outputs for all your speakers, and a subwoofer pre-out (unamplified) to drive a powered subwoofer.
    If you could point to which carver your were looking at perhaps we could explain more?
  8. Phil_M
    Phil_M Extra
    Mar 18, 2004
    21
    I'm not that confused....really. I'm sure my terminology is off....but I know what a typical receiver is.....and I have one. It is a Carver I bought ten years ago...the one that is 220W/channel (2). I need a surround setup now...and was going to start fresh for that....and move my receiver to the other side of the house...strictly for music. The power amp I'm looking at is the AV-505 with 5 outputs. My basic question would be ....what else would I need besides this amp? A preamp? plus the obvious DVD player. Forget the tuner(AM?FM)....so what unit does the different music formats? is it the preamp? or would I need something else?
  9. chung_sotheby
    Apr 8, 2002
    857
  10. Mike SJ
    Mike SJ Supporting Actor
    Nov 10, 2003
    718
    just to let you know, typical preamps start at $1000 and go up from there. Outlaw has a really nice one from what Ive read here, and they have matching power ams too. A b&k will run $1800 and up.
    What I use is a little device called the ADS 400 from Midiland
    http://www.midiland.com/proddetail.a...r=60&category=
    or Klipsch has a little pre/pro that does the same thing.
    http://www.klipsch.com/product/product.aspx?cid=433
    these little units are made for computers but work ok for HT. Im sure the sound quality isnt 100% but the one I bought was $130 and the klipsch is $170. Ron-P just purchased the Klipsch version I believe, get him to tell you how he likes his unit.
  11. Phil_M
    Phil_M Extra
    Mar 18, 2004
    21
    Thanks for the links etc. and all the information to help make my choices. There was very little, by the way, of information on seperates for HT. All I found was info about integrated amplifiers...(though I quickly scanned thru)and those aren't really seperates ...are they! I guess if I cannot spell sererates then I don't need 'um ...do I LOL! Unless of course I move to England.
  12. Mike SJ
    Nov 10, 2003
    718
    put it this way, a preamp handles bass, treble, volume, fade, pan, any surround decoding (dolby digital, prologic I - II - IIx, dts) and bass management and more. All an amp does is amplify the analog signalit receives and sends it to a speaker.
  13. ChrisWiggles
    Aug 19, 2002
    4,791
    Gotcha. So you'll be looking for a full-fledged HT pre/pro, and there are a bunch out there, but as noted, they are larger ticket items, so you'll probably be spending 1 or 2K or more for a high quality processor from rotel, lexicon, parasound, carver/sunfire, B&K, anthem, etc etc.
  14. John Prator
    John Prator Stunt Coordinator
    Mar 5, 2004
    152
    Phil,
    For what your looking for I would really recommend that you go to outlawaudio.com and check out their model 950. It will do everything you need it to and it is VERY highly rated. I do not have one of these pre/pro's but am familar with their products and they are of solid quality and they back up their products. I think the price on the 950 is in the $799-899 range and it will be almost impossible to get anywhere near their quality for that price. Do a search on AVS forum and here for the Outlaw 950 or even check out their receiver, the 1050($499) for info on their quality, etc. Hope this helps ya.[​IMG]
