ClassicTVMan1981X
What kind of DVD discs do such home media divisions use to put as many shows as possible without sacrificing the quality or original time length? As with VHS tapes, picture quality is reduced somewhat if many episodes are stuffed onto one disc if the wrong type is used. Typically, a DVD disc is 4.7 GB, which is only comfortable holding up to 120 minutes, or roughly 4 half-hours.
For example, on the Brady Bunch Season 1 DVD set, the first disc has seven episodes burned onto it, which without commercials is about 175 minutes long total.
But it gets problematic with longer shows like the freshly-released The Young Lawyers and Petrocelli. The pilots for these respective series alone were both 90 minutes long (or 75 minutes less commercials), but the standard episodes all average up to about 50 minutes without commercials. A single 4.7 GB DVD will not handle more than two episodes of shows of this length without sacrificing picture quality, which is why I believe they used dual-layer DVDs for these two series.
Regarding VHS tapes, SP (standard play) mode provides the best picture quality. Up to 4 half-hours can fit comfortably into a T-120 tape without losing this quality. The T-240 tape can hold up to 4 full hours in SP mode, but this format is rare.
~Ben
~Ben
