keir
- Jan 16, 2002
I usually listen to music at what i would call a moderate volume (probably 70 dB), but decided to crank it up a bit when i was listening to Rush - Tom sawyer. I noticed that it had a lot more impact at higher volume. It even sounds more balanced and natural at that volume.
Im running paradigm titans with a sony sa-wm40 that nicely integrates, and they seemed to "come alive" at higher volume more than im used to.
I measured the new volume at 80 dB on the radio shack meter (c weighting, slow setting). its probably a bit silly that I never tried this before
but i have a feeling ill be cranking it up more often. I bet many of you are used to 80 or even higher though. I would like to know what everyone listens at anyway!
edit: can't believe i used the wrong "your" in the title :frowning:
