What's wrong with too low a Qts/Qtc?
Discussion in 'Archived Threads 2001-2004' started by Michael R Price, Jan 8, 2002.
  1. Michael R Price
    Michael R Price Screenwriter
    Jul 22, 2001
    1,591
    I was just wondering... if lower Q subwoofers (like .5-.577) have better quality bass with less group delay, then what's wrong with having something like a Q of .4? I've read of low-Q drivers like the Maelstrom and BPD-03 drivers being turned away from IB use because they have 'too low' a Qts. Wouldn't a low Q provide a slower rolloff and hence deeper in-room bass? Wouldn't this slower rolloff cause a flatter phase response and hence, lower group delay? I'm a bit confused, since I've heard of both Q=.5 and Q=.577 as being 'critically damped.' What does that mean, and why would sound quality decrease below such a Q?
    As a side question, what is the problem with having an overdamped (way low-tuned) vented enclosure? Doesn't that emulate the characteristics of a low-Q sealed box? (In other words, I would think that the low tuning would cause the port output to 'mess up' the quality in the normal bass region less.)
    Ack thats a lot of questions, but this is something I'm pretty confused/curious about. Even though I have little chance of applying the knowledge anytime soon.
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
  3. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    One thing I've wondered Thomas, is why didn't you use Tempests for any of your IB subs?
  4. ThomasW
    Nov 6, 1999
    2,282
  5. Greg Monfort
    Greg Monfort Supporting Actor
    May 30, 2000
    884
    Correct.
    Correct.
    Q = 0.5 is critically damped and 0.577 is max flat delay response.
    Since it's overdamped, the driver can't reproduce all of the transient peak that's within its BW. IOW the LF driver's fundamental/first, etc. harmonics transient output won't be at the necessary amplitude to match the mid/HF output that completes it.
    This becomes a major issue with two-way and ~fullrange speaker systems, though not so much with subs since the room's Q boosts it to some extent.
    Same as with a sealed design.
    Correct, except it still has more group delay. If the GD attenuates before it's audible though, then it's a moot point and can actually have lower GD than a sealed in the audible BW, and why I prefer EBS alignments.
    In general, our hearing acuity falls pretty quick with decreasing frequency below ~200Hz, so even mass quantities of GD (which decays with increasing frequency) falls below our 'signal to noise' acuity if the tuning is
  6. Michael R Price
    Jul 22, 2001
    1,591
    Thanks for the answers, it seems as if there is nothing intrinsically wrong with a very low Q, but that...
    a) many drivers with low Q have other undesirable characteristics such as a high Fs
    b) a low-Q system may start rolling off at very high frequency (maybe 200 Hz) that would cause lean bass in a wide-range system
    That, plus the fact that unless you have an IB the box would usually have to be the size of a truck.
    I wonder if we'll ever see drivers specifically designed for IB/low-Q use... or do such drivers exist?
    Greg - Is there any particular 'rule of thumb' as to what group delay is inaudible... and is it better to have a flat group delay (even amount of delay at many frequencies, like a Q=.577[?]) or a lower overall, but not flat, group delay? I've heard numbers like 20ms at 20Hz... is there some sort of pre-determined number here, or is it an inexact thing?
  7. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    What about the mini IB though :p)
  8. ThomasW
    Nov 6, 1999
    2,282
    Michael
    Please clarify when you say IB are you talking about a relatively small sealed box?
  9. Greg Monfort
    May 30, 2000
    884
    This isn't necessarily undesirable, just that you need to match the driver to the application.
    Correct, some low Q pro drivers begin rolling off at ~700Hz.
    Yes, you need between 4-10x Vas depending on the driver.
    They used to be commom decades ago, except for high excursion capability, but with the advent of the materials/manufacturing revolution.....
    This has been debated for some time now and IMO it really boils down to the indiviual and the room it's in. FWIW, if it's 50ms/
  10. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
