What's the opinion on center channel placement for m-t-m designs?
Discussion in 'Archived Threads 2001-2004' started by Keir H, Jan 2, 2002.
  1. Keir H
    Keir H Second Unit
    Jan 4, 2001
    462
    Happy New Year!
    I have a large center channel (Def Tech CLR2000) and cannot help but to think that it suffers a bit with male dialog sequences. What are some tips on center channel placement to get the most out of them? Below or on top of a rptv? Vertical or horizontal? Opinions wanted please.
  2. Jim_Stu
    Jim_Stu Stunt Coordinator
    Dec 27, 2001
    134
    Keith H,
    1) Does your receiver have a built-in 'center channel'
    graphic equalizer? If not, correction may be very difficult.
    2) Does your receiver have separate, 'low level' outputs for each primary channel, in addition to its .1 sub output.
    3) I assume you have adjusted the 'center channel delay'.
    I spent last weekend taking care of a 'center channel'
    dialog problem with my HT set-up. My solution, although
    not popular, works very well.
    JRS
  3. Bob_A
    Bob_A Supporting Actor
    Jul 30, 2000
    876
    I would recommend that you experiment as much as possible...if it is on a rptv, make sure that it is placed as far forward as possible...with a slight overhang over the front end of the tv. Also make sure to angle the center downwards towards the listening position. But then again...if you have the space, you could try to place the center channel vertically. Good luck!
