Rain
- Mar 21, 2001
- Rain
Ok, so I've had this DVD for a while, but never really took a close look at it until last night.
According to www.imdb.com the OAR is 1.37:1. However, it is definitely not 1.37:1 on my copy of the DVD.
As you probably know, the Image Chaplins were windowboxed. Ok, fine. When I look at Modern Times, for example, I see a windowboxed frame on all the borders and the image appears to be about 1.37:1.
But with City Lights, I get no borders on the top and bottom of the screen, only on the sides, rendering an image which is narrrower than 1.37:1 (and significantly so).
Also looking at the frame on City Lights, I noticed that the corners are angular on the left side (top and bottom), but rounded on the right side (top and bottom). This makes it look a bit awkward as well.
Anyone have any idea what the heck is going on here?
