Whats the ideal crossover setting
Discussion in 'Speakers & Subwoofers' started by Gerard Martin, Aug 17, 2005.
  1. Gerard Martin
    Gerard Martin Second Unit
    May 22, 2000
    366
    For a Denon 3805 and Klipsch RF3, RC35 speakers all set to small. Early reply sincerely appreciated. Thanks
  2. Victor Ferguson
    Victor Ferguson Stunt Coordinator
    May 2, 2005
    120
    Well I would test in room response of my worst speaker, probably the center and set crossover to the closest setting just above its roll off point. I don't know if the Denon has the ability to select multiple crossover points but if it does I'd probably stay away from that and have all speakers cross over at the same freq.
  3. Mort Corey
    Mort Corey Supporting Actor
    Nov 21, 2003
    981
    Probably 80 would work well. You might also want to try setting the 3805 as LFE + mains and leave the mains set to large, depending on your sub (just to see if you like the difference)
    Mort
  4. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    I'm going with 60 for now.
