Whats the difference between 6/8 Ch inputs and Amp Inputs?
Discussion in 'Archived Threads 2001-2004' started by Jon Krangel, Mar 28, 2002.
  1. Jon Krangel
    Jon Krangel Stunt Coordinator
    Dec 14, 2001
    58
    I've seen a few really high end recievers that have these AMP IN inputs so that, if you wanted to, use them as amplifiers. Is it not true that a 6 channel or 8 channel input that you can find on almost any reciever (like the ones you plug DVD-A and SACD players into) would do the same thing? If so, then what is the point of these specialized AMP IN jacks (like the ones on the HK7000/8000)?
  2. Paul Clarke
    Paul Clarke Supporting Actor
    Jan 29, 2002
    998
    Hello Jon,
    To the best of my knowledge, the 5.1, 6.1 or 7.1 direct channel INPUTS are used only to import signal from an external sound decoder. PRE-OUTS, AMP IN(s) etc., are amplification paths. Main In(s) allow the use of external devices such as equalizers, etc.
