What's the best way to remove old paint from window glass?
Discussion in 'After Hours Lounge (Off Topic)' started by Drew Bethel, Feb 8, 2004.
  1. Drew Bethel
    Drew Bethel Screenwriter
    Nov 22, 1999
    1,209
    I heard of the old razor blade technique but was wondering if there is a more efficient remedy. Thanks.
  2. KyleS
    KyleS Screenwriter
    Jul 24, 2000
    1,232
    Drew,
    Do you know what kind of paint is on the window? If it is a oil style paint or even Latex then you could use some Paint Spirits with a squirt bottle on a mist spray. Spray the glass and whatever else you want to remove the paint from and then let it set. Repeat a couple of times to make sure the paint is loose then just use a paint scraper to easily remove the paint. The Razor blade will work well as long as you dont have a lot of surface area to remove.
    KyleS
  3. Drew Bethel
    Nov 22, 1999
    1,209
    Thanks Kyle, yes, it is most latex paint - I think. Our house has the old fashioned windows (built in 1937) so I won't be able to just spary and clean.
  4. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    Razor blade will probably be your best bet. The latex should come of easily in rubbery chunks.
  5. Danny Tse
    Danny Tse Producer
    Nov 1, 2000
    3,185
    Heat gun helps too....
  6. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    without question a razor blade. there isn't a simpler, faster or neater method that i can think of.
    using a wet solution will be messy. a heat-gun may actually soften the paint too much, casing it to get all goopy...
    you can buy special blades that kinda look like a drywall spatula - that way you have a safe grip with a wide scraping surface.
