JesseW
Grip
- Mar 30, 2003
soon, i will move into a new house, where ill be using the basement as my showroom. Since the screensize will be larger than joanns fabric offers budget blackout, and im too cheap to buy a good screen ...
I want to prep and paint a wall as a screen instead of using an actual screen. Should the wall be sanded down flat and as smooth as possible? Also, what normal paints would you want to use?
Thanx!
Thanx!
