What's the best way to get finger prints off the disc?
Discussion in 'Archived Threads 2001-2004' started by Ferdinand*T, Nov 26, 2002.
  1. Ferdinand*T
    Ferdinand*T Second Unit
    Nov 11, 2002
    284
    I bought a few dvd's today for cheap but a few have a couple of finger prints on them. What is the best way to get them off without scratching them? I trying to fog them up with my breath and wipe them gently with a very soft cloth. Is this good or is there a better way?
  2. Damin J Toell
    Damin J Toell Producer
    Mar 7, 2001
    3,762
    6
    Brooklyn, NY
    Damin J. Toell
    Look at a local music/movie store for special CD/DVD wipes. They're usually soft cloths that leave very little lint and don't scratch the disc surface. They're very handy for cleaning up used discs (a ritual that I often go through when acquiring used laserdiscs).
    DJ
  3. JohnS
    JohnS Producer
    Jan 17, 2001
    4,809
    143
    John Steffens
    What about that DVDdoctor contraption.
    Kind of pink or green and you spin the dvd, while it cleans it
  4. Juan C Toro
    Juan C Toro Stunt Coordinator
    Jul 23, 2001
    119
    Mom's spit works for everything.. If it cleans dirty faces, I don't see why it wouldn't clean a few fingerprints.
    [​IMG]
  5. David Rogers
    David Rogers Supporting Actor
    May 15, 2000
    722
    Disc Doctor is for resurfacing discs, not cleaning them. There's a huge difference; DD takes a small amount of the disc's surface off by shaving it to remove scratches and gouges from interfering with playback.
    Use a lens cloth (camera store, optician's) as those are designed to not scratch. Even normal cloth can scratch lenses and discs sometimes, so be careful.
  6. Tommy Ceez
    Tommy Ceez Second Unit
    Jul 16, 2002
    436
    Spread that powder on them and use the old tape lift method. You could watch CSI to brush up. Then enter the prints in a computer and apparently 1000 photographs will flash by in an instant before the face of someone you hadnt origionally considered a suspect appears.
    Oh....sorry....you meant how do you REMOVE fingerprints from a DVD! Oh...then forget everything I said.
  7. Bill McCamy
    Bill McCamy Second Unit
    Jan 1, 1999
    268
    To continue the deterioration of this thread:
    Apply a light coating of rubbing alcohol to the affected side of the disc. Remember to wipe in a straight motion from the center of the disc to the outer edge. Do not use a circular motion.
    Hold the disc over an open flame (a bic lighter is perfect), until you observe the flash of ignition.
  8. Nate Anderson
    Nate Anderson Screenwriter
    Jan 18, 2001
    1,152
  9. Juan C Toro
    Jul 23, 2001
    119
  10. Nate Anderson
    Jan 18, 2001
    1,152
