Dustin B
- Mar 10, 2001
The rocket RS150, the Axiom M22Ti or the Ascend CBM-170This is a matter of opinion, but for me the M22Ti is a great speaker. I havent heard the RS150, but by specs the AXIOM will be a better pick.
Good luck,
Pablo
Center: (dont know of a good one in my price range or if one is needed)The speaker that you should consider is the AXIOM VP100, but many in here say that the difference between the VP100 and the VP150 is incredible. But this will be a matter of choosing after you choose your receiver, to see how much you will have to spare in your $2500 budget. And aslo remeber that Axiom has a 30 day return policy so you cant test them and if you dont like them just return them, but I'm sure you will like them a lot.
So my suggestion could be
Marantz SR7300 $700 ($900 in authorize dealler)
Axiom M22ti $800 (axiom direct)
Axiom VP150 $350 (axiom direct)
SVS 20-39PCi $600 (svs)
TOTAL about $2000 + shipings, inside your budget.
Hope this helps,
Pablo
