What's the best 'active servo' sub on the market for the money?
Discussion in 'Speakers & Subwoofers' started by KyleT, Jul 7, 2003.
  1. KyleT
    KyleT Stunt Coordinator
    Nov 8, 2002
    59
    I need a recommendation on something that will sound as natural as possible. Accuracy and 'tightness' of bass is more important than being able to rattle the walls.
    Also... any reasons why I should consider a non active-servo sub besides price?
    I'd like to keep the price under 2k.
  2. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
    I haven't heard the Velodyne Servo, but I do own a Paradigm Servo-15. Since I listen to 50/50 Music/Movies I was also looking for a Sub that was 'tight'. I have been extremely happy with my purchase in that regard. It also kicks some serious butt with SPL levels on movies should I decide to crank it up.
    Here is the Velodyne 12 review on Secrets - I have to believe the price has come down since 1998:
    http://www.hometheaterhifi.com/volum...dynehgs12.html
    The Velodyne 18 is a giant but above your price point:
    http://www.hometheaterhifi.com/volum...subwoofer.html
    Here are some reviews on the Paradigm site:
    http://www.paradigm.com/Website/Site...rvoSeries.html
    I'm not sure where you are located but I paid 1300CDN (975US) plus tax for my Servo-15. I believe price in the US would 'probably' be around 1200 out the door, YMMV.
  3. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Paul hits the nail on the head, and in fact, I don't know of any other servo subs other than Paradigm and Velodyne. (I had an HGS-10, then a 12 for a while.)
    Price is a big deal though. I went from the HGS-12 to a Vandersteen V2W. I get the equivalent of a 15" sub (3x8"), but at a cheaper price than for the HGS-12. (Vandersteen uses Feed Forward Error Correction as their technological solution to distortion at high outputs and low freqs.)
    Don't "discount" [​IMG] SVS and Hsu Research though. They just use genuine long throw drivers to more or less accomplish the same thing.
    James Loudspeaker also has a new tech solution to distortion, but again, not cheap. Getting very good reviews too.
  4. Ron_L
    Ron_L Second Unit
    Feb 21, 2002
    273
    Servodrive is the company and I was just gonna mention that.
    They are made for COMMERICAL applications though.
    I can vouch for the Servo15, it just kicks ass.
  5. Sihan Goi
    Sihan Goi Second Unit
    Nov 2, 2001
    442
    I can vouch for the Servo-15 too [​IMG]
  6. ShaunLB
    ShaunLB Stunt Coordinator
    Apr 17, 2003
    141
  7. KyleT
    Nov 8, 2002
    59
  8. Greg Bright
    Greg Bright Second Unit
    Feb 24, 2000
    266
    2
    110
    Gregory Bright
    As far as I can tell, all that servo subs do is limit distortion at high volume levels. As the overall sound gets louder the sub stays at the same level above a given point. If you intend to listen at ear-bleed levels then a servo would probably be the right choice. OTOH if good clean low bass at normal levels is what you want, you could save some money with a non-servo model. Just my two cents.
    Greg
  9. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
  10. Kevin C Brown
    Aug 3, 2000
    5,712
    Kyle- No, I think you are on the right track. [​IMG] Just that servo's are only *one* way to get good clean, deep, bass output.
  11. Jaime B
    Jaime B Stunt Coordinator
    May 28, 2002
    140
    Kyle:
    The Velodyne HGS Mk.II-10" goes for $1,899. I can vouch for the Mk.I. Beautiful, tight bass! Look, Kevin Brown hinted at the James Speakers Sobwoofer. It is the latest rage (for those in the know, that is) as a truly musical and potent sub. The smallesr model goes for $1,795, I believe. Try to audition it, if you can (I haven't), if not the Velo will make you more than happy.
    JaimeB
  12. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
  13. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    I think the idea setup would be a folded bass horn in your
    foundation running 12 18" Pro Subs on a couple killowatts
    of power [​IMG]
    I agree though a properly built sub using quality components
    throughout won't need Servo Technology to sound fantastic.
    (Not the type of Servo that Velo or Yamaha uses anyway..
    Servo-Drive is a completely different story!)
  14. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    I'm with Jack on this one. I think NASCAR is a good analogy when thinking of servo controlled subs. Imagine putting a 1000 horsepower motor in a car and then adding a restrictor plate to limit the car's full potential.
    Or in terms that Brett can understand, buying a Corvette and not driving it over 55MPH! [​IMG]
  15. Brian Bunge
    Sep 11, 2000
    3,716
    Jack,
    I'd imagine that would be quite possible too. It doesn't matter much what the quality of the driver is as long as the servo keeps it in check.
