What's in your closet??? 28 -15" Subs??
Discussion in 'Home Theater Projects' started by Shawn Keeler, Feb 26, 2004.
  1. Shawn Keeler
    Shawn Keeler Stunt Coordinator
    Feb 2, 2003
    190
    Thought you would like to see the Treo subwoofer "demonstration" chamber at our store. We are using 28 Treo Engineering 15" Subwoofers. This would be a killer HT Closet set up.
    Our theater that we are building right now in the store will be using to Treo Engineering 18" subs in a 26 cubic foot ported enclosure. Going to get down!!!!
    This pic will get the mind thinking!!!
    Later, Shawn
    [​IMG]
  2. SurfHB
    SurfHB Extra
    Sep 6, 2003
    18
  3. Neil White
    Neil White Supporting Actor
    Jan 8, 1999
    551
    I would imagine being anywhere close to that would be like being a pressure chamber that deep sea divers have to decompress in.
    N
  4. Owen Bartley
    Owen Bartley Second Unit
    Nov 11, 2002
    487
    Dude, how much power is going into all those? And what's on the table?
    That looks like it could satisfy ANY basshead's needs! [​IMG]
  5. Shawn Keeler
    Feb 2, 2003
    190
    If you have long hair it literally stands straight up!!! Here is a video clip below, if you want to check it out.
    http://www.metroaudiodynamics.com/storetour.html
    Shawn
    About a total of 4,000 watts. That table is the amplifier with a "burp" button. To give a 3 second bass blast!!!
  6. Jeran Kuenzie
    Nov 19, 2003
    32
    Are those 9.0s (the Zapcos)? How are you running them indoors? Do you just have them hooked up to batteries, or are you running some kind of inverter?
  7. Shawn Keeler
    Feb 2, 2003
    190
    Tons of batteries and a charging power supply. Also A lot of Dynamat!!!
  8. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    Cripes! How did that chick keep a smile on her face? Her brains must be mush after that demonstration!
  9. Shawn Keeler
    Feb 2, 2003
    190
    Easy, her boyfriend owns the store!!!!
  10. Alexandre L
    Alexandre L Auditioning
    Feb 28, 2004
    2
    Hi all, I know I'm a little bit off topic but where did you bought tose seats Keeler because they are awesome and so is your theater. Alexandre
  11. Shawn Keeler
    Feb 2, 2003
    190
    Click on my website link above for information.
  12. Alexandre L
    Feb 28, 2004
    2
    I never think to check out there Thanks!
