I've never used them but many others have and say good things including Steve DeckertFrom the table of contents select Speakers | Misc speakers | Decware 10 inch three way.
It depends on which driver and what your application is.
I have used their 55-1465, a dual voice coil 12" with a rubber surround and poly treated paper cone. I had it in my car and it was quite good in that application (two of them, actually). However, the Fs is a bit too high and Qts a bit too low for home application, in my opinion. It's a great value, but I think the Dayton Quatro line is a better value.
Overall, the quality of MCM woofers is quite good, with nice construction, appearance, and performance. The reason you spend so much less is the relatively low Xmax. MCM now sells some higher Xmax woofer (about 13mm), but the price is much higher. Unfortunately they do not specify Xmax on most of their woofers. Even with the low Xmax though, just glancing through their pages, it seems in terms of swept volume per dollar, a few of the MCM woofers beat out the Quatros or Adire units. But these days, there is only so much you can do with a subwoofer having only 4mm of excursion, even if it is only $20.
Yeah I'll post some later and tell me what your opinions are on that sub. I'm new to this and want to build a budget sub for my room. I'm also planning on using their 250watt amp for like $90. Any opinions on their amp
This one looks like a great value, much better value than the Dayton Quatro 12". In fact, in theory, it could give you about 85% of the Dayton 15" Quatro at 71% the price. I suspect this one may have a rather large magnetic field though. Durability may be an unknown, however. The Daytons come with a five year warranty.
Michael, much as I love comparing specs and prices and such, eventually you'll just need to pick something. There are dozens and dozens of good woofers out there, perhaps hundreds. You'll just need to decide which features are most important to you and what your maximum budget is.
just a little help here. I do not know much but I have seen your posts. PE just posted a bunch of stuff on the S&D (scratch and dent) page. everything is marked down. they have a DAYTON 15" SERIES II WOOFER for 60 instead of 80.
