What's best to put under my bookshelf speakers
Discussion in 'Archived Threads 2001-2004' started by Robert_Dufresne, Mar 15, 2003.
  1. Robert_Dufresne
    Robert_Dufresne Stunt Coordinator
    Mar 30, 2002
    246
    I have a pair of Studio 20 resting on bookshelves. The
    bookshelves are solid but I think I should put something
    under my speakers so they don't rest on the shelf ( wood against wood ). Would blue-tack be good or should I use
    something like carpet under padding or just plain rubber
    feet.
    Help would be appreciated[​IMG]
  2. Ron_L
    Ron_L Second Unit
    Feb 21, 2002
    273
    try some of that anti-slip material that most rv'ers use.
  3. Marc H
    Marc H Second Unit
    Aug 22, 2001
    497
    An old mouse pad?
  4. TommyL
    TommyL Supporting Actor
    May 27, 2002
    590
    blu tack...2 bucks or less...works great..I have studio 20's also[​IMG]
  5. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
    I use that non skid rubber matting that is sold to go underneath throw rugs. Probably the same stuff Ron_L is talking about.
  6. M_a_r_k^NE
    M_a_r_k^NE Agent
    Feb 19, 2003
    42
    Sorbathane damping pads. Can pick a slab from audioadvisor.com for $20.00. Cut in small squares and place them under your speakers. They're self adhesive too. The sound will improve. I use them under my small speakers.
  7. Nathan Porteous
    Nathan Porteous Stunt Coordinator
    Feb 18, 2003
    109
    use asprin they're cheap and after all the noise you can use them. got the tip from audio mag works great
  8. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    YOu studio 20 guys, sorta off-topic, but do you have the veneered version or the laminate? And were you able to listen to both, if so is there a SOUND difference between the two? I really don't care about the looks, the laminate is fine, and the extra couple hundred is significant for what is mainly looks. I've heard the real-wood stiffens the cabinet a tad, but I still can't see there being THAT much of a difference in sound. What do you think, $650 for laminate, or $900 for veneer?
  9. Robert_Dufresne
    Mar 30, 2002
    246
    Chris
    I have the laminate version and yes I listened to both.
    No difference IMO . The speaker shell is made from MDF
    in both cases. The only difference is in the look and the
    price.
  10. TommyL
    May 27, 2002
    590
    ditto..[​IMG] Grab the laminate, and put the 250 bucks toward something else.
  11. TommyL
    May 27, 2002
    590
    I just reread a thread from a while back on another board..guy contacted paradigm a few times...said the same thing[​IMG] his sentence--->
    I've checked with Paradigm on this to be sure:
    They are the same. The veneer models simply get that piece of wood with the curved edges applied to the existing MDF sides. So the underlying MDF construction, bracing etc. is *identical*. It is meant as a looks thing only.
    The veneer is only on 2 sides fyi...basically all looks..hey, if you have all cherry in your HT room..I'd go with cherry...these are paradigms top speaker...if people really like them, give them the option to ante up some more cash and get a few options..right? I would.
