What's a great flat panel for watching DVD's via DVI?
Discussion in 'Computers' started by Jonathan Burk, Aug 18, 2003.
  1. Jonathan Burk
    Jonathan Burk Second Unit
    May 31, 1999
    452
    4
    Castaic, CA
    Jonathan Burk
    I've got a Bravo DVD player with DVI output. You can now customize the DVI resolution as well. What is the best flat panel 19" for watching DVDs (without going stratospheric on the price)? Does anyone have a recommendation?
  2. Jason Merrick
    Jason Merrick Supporting Actor
    Mar 2, 2000
    696
    Simi Valley, CA (Los Angeles)
    Jason Merrick
    The stratospheric price limitation will probably eliminate this, but knowing your likely application for this, have you considered the Apple widescreen display? I think it's called the cinema something or other... (Great name, huh?!)
    [​IMG]
  3. Jason Merrick
    Mar 2, 2000
    696
    Jason Merrick
    Either the 20" or 23" one of these would fit the bill!
    Of course, you would have to add $99 to that price for a DVI->ADC connector.
    [​IMG]
  4. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    Do you have a rough estimate on a budget?
  5. Jonathan Burk
    May 31, 1999
    452
    4
    Castaic, CA
    Jonathan Burk
    I would be fine up to about $1000, depending on the size. I could go up higher if there is a huge increase in quality.
    I think at least 19" 4x3.
  6. Gabriel_Lam
    Mar 7, 2002
    1,402
    The best for DVD's at that price is probably the $999.99 (after rebate) Real Digital RD2200 22" 16:9 display:
    [​IMG][​IMG]
    [​IMG][​IMG]
    Real Digital RD2200
    It's the native resolution of DVD on square pixel fixed pixel displays. DVI input too, of course. 400:1 contrast, very bright at 420 nits, and 16ms total average response (very fast).
  7. Jonathan Burk
    May 31, 1999
    452
    4
    Castaic, CA
    Jonathan Burk
    That looks like it's just what I'm looking for. Thanks!
