What's a good Surround sound processor in $200 ~ $500
Discussion in 'AV Receivers' started by Tim_, Jun 25, 2006.
  1. Tim_
    Tim_ Stunt Coordinator
    Mar 25, 2005
    95
    What's a good Surround sound processor in $200 ~ $500? I been looking for one but it seem like no one is making them anymore. A pure surround sound processor.
  2. FeisalK
    FeisalK Screenwriter
    May 1, 2003
    1,245
  3. Tom Donaghue
    Tom Donaghue Stunt Coordinator
    Aug 18, 2005
    222
    Tim;
    Would you consider using a good mid-level A/V receiver as your processor? I've had very good results with my setup in this capacity, previously with a Denon AVR-3803 and currently using a Yamaha RX-V2500.
    I'm not using any of the internal amps of the Yamaha, so its sole purpose in this configuration is as a pre/pro and in the past four months or so I've been using it, I've had fantastic results.
    Several mid-level receivers at your price point will outperform dedicated processors, will allow you a better resale value if at some point you decide to upgrade and also provide some back up in the event you needed to service your dedicated amp/s.
    Just a consideration... -TD
