What's a good amp match for Energy C-
Discussion in 'Archived Threads 2001-2004' started by Ryan_C, Feb 14, 2002.
  1. Ryan_C
    Ryan_C Second Unit
    Aug 9, 2000
    369
    I was tossing around the idea of getting a 3 channel amp around 200 watts per channel for my front and center speakers. My mains are Energy C-6's, and my center is an Energy AC-300. I know Rotel and Parasound make (or made) 3 channel amps with the power I am looking for. Does anyone have any experience with either of these amps and my speakers, or have other recommendations? Thanks in advance!
    (I also posted this ? in the speaker section, I wasn't sure which it really belonged in)
  2. Rob Blakeslee
    Rob Blakeslee Auditioning
    Sep 30, 1998
    13
    Ryan,
    I have the same speakers you do and I use an Aragon 4004 mk II. I know it is only two channel, but it really sounds great. I use a B&K AVR202 to power the rest. Not knowing your budget, you could try an Aragon 8008x3, Acurus A200x3 or the amps that you mentioned. Check the used market and you would be surprised what you can find plus it may allow you to get an amp that you wouldnt've been able to afford new.
    Good Luck !!
    Rob
