Gerard Martin
- May 22, 2000
In terms of customer support, reliability, programming, price, picture quality, which supports 5.1. What do you have and are you satisfied?. I would require two receivers. TIA.
Was the prices you quoted for one or two receivers or does it matter, does DirectTVMost DirectTV deals will cost another $5/mth per additional receiver.
DirectTV does support DD 5.1. It requires a different receiver than the basic model. The RCA receiver has an optical output for digital sound. It does not have a digital coax output. I think that this is true for the Sony version as well. Either the RCA or Sony digital will cost about $100 more than the basic receiver. Personally I went with a receiver for digital sound for my main system and the basic receiver for the bedroom.
However, the amount of programming that has 5.1 sound is minimal.
:frowning:
save your money on the 5.1 unit,get the analog and a good prologic 2 reciever,my brother paid 350.00$ for a sony w/digital out and my analog sounds much betterI hope you were kidding Shane??
Listening to PPV and Starz/HBO Directv w/ 5.1 output sounds MUCH better than any Prologic set up.
Plus the receivers w/ 5.1 aren't that expensive these days..$150 tops.
