What video card for a big screen?
Discussion in 'Computers' started by RobLJ, Mar 3, 2004.
  1. RobLJ
    RobLJ Stunt Coordinator
    Jan 7, 2004
    81
  2. Chris
    Chris Lead Actor
    Jul 4, 1997
    6,788
    I'm not sure for what purpose. If you've got that kind of nice screen though, you're best off to find an ATI 9700AIW or 9800AIW just for the high-def outputs [​IMG]
  3. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Sapphire Radeon 9600 would be ideal since it has no fan. 9200 if on a budget.
    edit- Newegg link. DVI port for the tv.
  4. Jim Robbins
    Jim Robbins Stunt Coordinator
    Sep 3, 1998
    233
    I second the Radeon 9600. It was selling for as low as $90 with rebate when I bought mine. I run the DVI to my Sharp DLP and get great HD from the Microsoft WMV-HD "Coral Reef Adventure" DVD.
  5. DougWright
    DougWright Stunt Coordinator
    Mar 24, 2000
    155
    I have a Sony KP65WS500 and it's manual states the DVI port is not for use with computers. Does anyone know if this is just them covering the bases, or is there a reason my video cards (NVIDIA GForce Ti 4200) DVI out would not work with my TV? Could the TV get damaged by trying this hookup?
  6. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    I think it's just a matter of researching what kind of output signal is needed to send to the TV. Before you do it make Powerstrip your friend, and research your set in the HTPC section of AVS.
  7. videobruce
    videobruce Stunt Coordinator
    Sep 23, 2003
    143
    Which 9600?
    I believe ther are at least 3 different versions!
