What "tweak" gave you the "most bang for your buck"?
Discussion in 'AV Receivers' started by EdNichols, Jul 21, 2003.
  1. EdNichols
    EdNichols Second Unit
    Feb 15, 2003
    372
    I have read threads where someone adjusted this or moved that and it made such a difference in sound. Since I am always in the market for free or low cost sound improvements, what tweak did you do that gave you a better sound?
  2. Craig Morris
    Craig Morris Stunt Coordinator
    Oct 10, 1998
    195
    Speaker placement. I moved my subwoofer about 1 foot forward and filled in a hole I had between 80-100Hz. I also pulled my main speakers out a few feet further into the room. The soundstage, imaging and midrange clarity are so much better than when the speakers were about 2-3 feet back from where they are now. Yes, they are practically in the middle of the room which would drive some people crazy, but I live alone, and after hearing my speakers in their new spot, I could never go back.
  3. PhilMays
    PhilMays Stunt Coordinator
    Jul 1, 2003
    53
    For the Money?
    Going to 12 guage speakerwire from 14 guage.
  4. Brian OK
    Brian OK Supporting Actor
    Aug 29, 2000
    550
    Acoustical treatment for the listening room. DIY panels and bass traps, etc, are very low cost and can do wonders.
    Moreso than upgrading amps and processors, even speakers, IME.
    Definately worth investigating if you are looking to smooth out your rooms response.
    Good Luck,
    BOK
  5. Dan Driscoll
    Dan Driscoll Supporting Actor
    Aug 1, 2000
    937
    2
    Absolutely no contest, proper speaker placement is unquestionably the most cost effective tweak there is. Moving the speakers costs no money, yet can potentially improve sound quality by orders of magnitude.
    Of course, if your speakers are already properly positioned this won't work for you, so you'll have to look at another aspect of your system. If you have junk speakers, perhaps replacing them with low cost, but decent quality models would be the most effective tweak. How about your romm, would some wall treatments help? If you are using the patch cords that came with your components, upgrading to inexpensive, but good quality interconnects might yield the best "bang for the buck" improvements. IOW, the best tweak will depend on your specific system and circumstances.
  6. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    Absolutely agree that moving speakers esp the sub will work wonders for the sound of your system at no cost. I moved speakers farther away from side and back walls. Moved sub from the corner to a side with no side wall but just back wall. This flattened my room response to be within +/- 3db from 80-20Khz. I now only have a 5db peak at 40Hz that I want to take off. Maybe getting the Outlaw ICBM would do the trick for $250. We'll see but so far nothing is planned.
  7. RobertR
    RobertR Lead Actor
    Dec 19, 1998
    9,952
    343
    9,110
    No question, proper speaker placement and room treatment DWARFS any other "tweak" by orders of magnitude.
  8. RayJK
    RayJK Stunt Coordinator
    Nov 25, 2002
    131
    After speaker placement, balanced power did it for me.
  9. Carlo Medina
    Carlo Medina Executive Producer
    Oct 31, 1997
    10,602
    760
    9,110
    Speaker placement. Best bang for the buck, even when you factor in what I'm worth per hour! [​IMG]
    After that, a true powerful amp section (upgraded from Sony STR-DA555ES to an NAD T762).
  10. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
    Speaker placement is easily number one on my list too.
    Number two in my system was eq'ing my sub. I added the Behringer Feedback Destroyer for $120 and I'll never have another system without an eq for my bass.
  11. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Speaker placement. *Gots* to be at least 18" out from any wall. Then, getting a BFD eq for my sub. Then, getting the phase correct between the sub and mains. Next was routing my CATV line through the ground loop isolator in my AC box (balanced power). Next was actually using the video section on Avia (I had always used the audio parts...). [​IMG]
  12. NickSP
    NickSP Supporting Actor
    May 8, 2001
    569
    Speaker placement and especially the Subwoofer made a tremendous difference and best of all, no money changed hands. Of course if selling a few receivers and going the seperates route is a tweak then that was one helluva tweak [​IMG] [​IMG]
  13. Michael Mohrmann
    Michael Mohrmann Screenwriter
    Dec 30, 2001
    1,394
    Kevin,
  14. Levesque
    Levesque Supporting Actor
    Mar 21, 2002
    586
    Putting 3 big 2 inches slab of concrete under my Servo-15. Cost me 15$ (CDN! imagine!). Big improvment for me for cheap.
  15. DaleBesh
    DaleBesh Stunt Coordinator
    Oct 26, 2002
    163
    1. Speaker placement (assuming good quality spkrs. to start with)
    2. Some room treatments
    3. Going with separates
    4. Cables...do not have to be esoteric, just the right cable for the job, and quality workmanship and construction
  16. Steve_D
    Steve_D Second Unit
    Nov 28, 1999
    299
    SPL meter and a good test tone CD
  17. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Physical matting for my RPTV.
  18. Scott Merryfield
    Dec 16, 1998
    12,639
    1,290
    9,110
    Where I actually spent money? It would still be speaker placement. I purchased a pair of rubber door stop wedges for less than $1 to properly angle my center speaker towards the listening position.
  19. Lee Scoggins
    Lee Scoggins Producer
    Aug 30, 2001
    6,394
    Lee
  20. Burke Strickland
    Burke Strickland Second Unit
    Jul 31, 1997
    271
    The Cardas speaker placement/room setup data is very useful indeed. I have based placement of my Maggies on the formulas given there (with some additional minor tweaking). The material explaining the formulas is also quite interesting. The area on the Cardas site with the room setup information is in the section labeled "Insights" at http://www.cardas.com/insights/index.html
    Select "Room Setup" from the list on the right-hand side of the "Insights" page (about 2/3 of the way down the list between "Cable and Connector Longevity" and "Record Mastering, an interview with Stan Ricker Part 1"). The page with the information will be titled "Setting Up Speakers In A Rectangular Room". It has formulas that are useful for owners of planar speakers (such as the Maggies) and for more traditional box speakers (virtually all others).
    In case you want to learn even more, there is a link at the bottom of the page "For those who must know more... " which in turn takes you to a page of links to a lot of additional information such as "Long Wall Speaker Placement or Horizontal Listening Rooms" and more...
