Lone Fox
- Aug 1, 2012
- Cory
I'm trying to narrow down my choices for a "bedroom TV".
So far, LG is the only brand I can confirm that: (1) you can turn the internal speakers off and (2) adjust the volume with the speakers off does not display an on-screen warning that the speakers are disabled like some other TVs do. I don't know if all LG TVs are like this, just the two 32" display models at Bestbuy that I tested.
You don't have to read all below, the main question is the title: What TVs do not give an on-screen display warning for when you adjust the volume with the TV's speakers turned off, because I will be using a soundbar.
I'm looking for 24/26" - 32" range nothing smaller or bigger. I'm thinking a 32" may look best with a soundbar, because I will mount the soundbar to the TV's wall mount feature.
Since small TVs have terrible speakers and I will be using a soundbar, I noticed not all TVs give the option to turn off their speakers. This is usually confirmed testing in store (Bestbuy) or reading the manual online. I'm actually not sure, but if one where to connect to the TV's digital output (if supplied) would this disable the TVs speakers? I don't want the soundbar and TV to play audio at the same time.
I also notice a TV at Bestbuy (can't remember which brand/model) that when you turn the speakers off (menu setting) and adjust the volume it gives an onscreen warning telling you the speakers are off/muted. One of the cheap soundbars I'm looking at does not come with a remote, but can be programmed by the TV's remote. The reason I bring this up is because every time one adjust the soundbars volume the display warning will come up. Otherwise, regardless if the soundbar I choose comes with a remote or not I DO NOT want an on screen warning popping up every time I adjust the volume with the TV's remote.
I was unable to test some of the TVs at Bestbuy because it looks like the LED TVs do not have physical buttons on the unit itself, and Bestbuy does not have the remotes attached to their display TVs. One TV brand (can't remember) has menu buttons, but can only navigate the menu with the remote control.
