What to use to wipe down CRTs in an RPTV?
Discussion in 'Displays' started by Carlo Medina, Sep 15, 2003.
  1. Carlo Medina
    Carlo Medina Executive Producer
    Oct 31, 1997
    10,601
    759
    9,110
    I'm going to be opening up the back of my RPTV to clean the CRT lenses. I live in a moderate-dust environment and it's been at least a year and a half since they were cleaned (during ISF calibration).
    What do you all (esp the ISF guys who frequent this board) recommend for wiping dust off of RPTV lenses?
    Thanks!
  2. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
    Hi Carlo
    First use canned air to blow off any dust, then I use prepackaged eyeglass lense cleaner (small paper towel that is prewet) to clean off the glass. NOW BEFORE it dries use a soft / eyeglass cleaning cloth to buff off the cleaner and remove any streaks. This works like a charm.
    regards
    Gregg
  3. Carlo Medina
    Oct 31, 1997
    10,601
    759
    9,110
    Thanks Gregg! Phew, thank goodness I live near an Office Depot! (that's about the only place I can think of for compressed air)
    There might be an optometrist in Westwood where I can get the eyeglass cleaner supplies...
    [​IMG]
  4. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Also try micro fibre rag for cleaning computer monitors ... available at OD or stap ...
    Regards
  5. Sean Romo
    Sean Romo Agent
    Feb 3, 2003
    34
    Before I tear apart my TV, what is the best way to access the lenses. Do I start in the front or the back?
