What to turn off in XP to stop unwanted pop-up banner ads?
Discussion in 'Computers' started by Ronald Epstein, Jul 23, 2005.
  1. Ronald Epstein
    Ronald Epstein Founder
    47,666
    5,057
    My friend at work is having problems with
    pop-up ads saying his Windows has found a
    critical error and then pushes for a fix product.
    He gets these ads continually ever few seconds
    after he closes them.
    I distinctly remember having this problem a
    few years back and the fix involved going into
    Windows messenger or Control Panel and turning
    off a function that allowed such banners.
    Can anyone tell me the procedure?
  2. jason_l_h
    jason_l_h Agent
    Feb 27, 2005
    32
    Type in services.msc at the run prompt and disable messenger service.
  3. Robert_Gaither
    Robert_Gaither Screenwriter
    Mar 12, 2002
    1,370
    Does your friend do windows update often? I know on a recent reinstall I had this same problem before the patches loaded and afterwards it disappeared.
  4. Ronald Epstein
    47,666
    5,057
    Robert,
    Don't know, but I have already forwarded him
    this information and I thank you both very much
    for it.
  5. Sonnie Parker
    Sonnie Parker Second Unit
    Dec 11, 2001
    407
    Sounds like a typical pop-up ad caused from adware. Does he have Spybot Search & Destroy, Microsoft Antispyware, and Adware Personal SE, all installed? These are pretty much 3 must have free programs that will eliminate the ads. Plus SP2 has the pop-up blocker that works well.
