What to Look for in 27" Flat Screen TV??
Discussion in 'Displays' started by Chris:K, Sep 16, 2003.
  1. Chris:K
    Chris:K Auditioning
    Sep 12, 2003
    4
    What are some things I should be looking for when purchasing a 27" flat screen? Also, what are some dependable brands for televisions?
    - Chris
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Flat, 27", HD capable. Not a whole lot more you need to look for. How about a price range?
  3. Chris:K
    Chris:K Auditioning
    Sep 12, 2003
    4
    Well I'd like to keep it around $400. I'm also highly interested in a HT setup, but first things first, and I need a new TV. Plus I need to do a ton more research on HT setups before I even think about purchasing one. Anyway, what are some brands to keep an eye out for while television shopping?
  4. Roy Bass
    Roy Bass Auditioning
    Sep 16, 2003
    Vertical Compression (16:9 enhanced mode)to use all 480 lines(in most cases) within the actual viewing area. Other wise you're only going to get around 270 lines. I bought the Sharp 27F631 at Best Buy for around $350. It's nice tv for the price IMO. I heard the Sony models do the V-compression automatically but i think it only works with the S-Video input, i could be wrong though. With the Sharp you have to go into the menue to swith between 4:3 and 16:9, but it's pretty easy to get to. Just make sure you set your DVD player to 16:9 while using it. Samsung makes a 27" model that does 480p from all sources. It's considered an EDTV not an HDTV(480p and 1080i or even 720p). Circuit City sells them for around $450 i believe. Scan lines aren't that noticible on a 27" IMO, especially while using v-compresssion but you'd get better use of a quality progressive scan dvd player with a 480p capable tv.
  5. Chris:K
    Chris:K Auditioning
    Sep 12, 2003
    4
    Thanks for the reply! What is EDTV though? Also, I was looking at a Samsung 27" that looked really nice. How are Samsungs in the quality and reliability department? I'm basically looking for something that will last me quite a few years.
    - Chris
