What to do for top endcap of sonosub?
Discussion in 'Archived Threads 2001-2004' started by Seungsoo Hwang, Mar 13, 2001.
  1. Seungsoo Hwang
    Seungsoo Hwang Stunt Coordinator
    Aug 6, 1999
    204
    I have cut out my MDF circles for the sonosub I am building, and I wanted to make a .75" top that is not in the tube, and overhangs a bit to finish off the top.
    Info on sub, 18" Diameter, 2 internal endcaps, top/bottom, and is ported out the top via 2 3" ports. I did a texture paint endcap on my previous sub, and it came out ok, but didn't look all that great. Being so tall I rarely see the top of it anyways so it didnt matter then. This sub is much smaller than the last, so it will have to look nicer. I wanted something similar to what TerryC did on his shiva: http://terryctheater.tripod.com/shiv...bum/page2.html
    Questions:
    Can you get "iron-on veneer tape" at home depot?
    How easily does it apply and finish?
    I suppose the easiest method would be to just use a piece of hardwood, but how much would a piece around 20"D cost?
    Im thinking of just getting some plywood to save money and veneering the edge, and top if neccessary.
    thanks
  2. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
    Hi!
    check out my links below. I used pine board for the caps, and some wipe on stain with a aerosol strain lacquer.
    I would consider:
    2 12" pine boards, about $15 each at home depot
    glue them end to end to make them large enough.
    one can of stain (about $3-5)
    one can of lacquer (about $ 5)
    Put on muliple coat of lacquer to get a nice high gloss shine.
    Gregg
    The Sonodome
    The Newest Sonotube
    Gregg's DVDs
    and LDs
    The Family Units
  3. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    Greg, I have to ask, your 30" sonotube has got to be about 32" with the wider caps. Did you build it in the room it's in? Or can you move it out the long way if need be? I'd love that, but I can't maneuver it, I'd have to fit it in standing up.
    http://content.communities.msn.com/i...&ID_Message=43
  4. Chris Hoppe
    Chris Hoppe Stunt Coordinator
    Sep 5, 2000
    53
    Yes, home depot carries 7/8" veneer tape. (it is oversized to fit 3/4" wood)
    It is hot glue adhesive backed, and applies with a hot dry iron. Very easy! I did it perfect the first time I ever worked with it.
  5. Gregg Loewen
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
    The 30" tube I used actually had a inner diameter of 30 7/8 ". The outer diameter was about 31.5. I made the cap 32" 1/4. Yes you have to be careful to make sure your doors are large enough to pass the item through. My door is 33" (thank god!) [​IMG]
    Gregg
    The Sonodome
    The Newest Sonotube
    Gregg's DVDs
    and LDs
    The Family Units
  6. Gregg Loewen
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
    Actually, I just remembered I glued my caps on in my HT room as I didnt want to mess with it in the area where I had done all the wood cutting (I had not bothered to sweep and clean up yet). I have not done the measurements...I sure hope I can move my new tube out if I ever decide I need to.
    Thinking further, it was a tight fit to get the tube through the door without the caps, :/ ???
    Gregg
    The Sonodome
    The Newest Sonotube
    Gregg's DVDs
    and LDs
    The Family Units
  7. Jack Gilvey
    Mar 13, 1999
    4,948
  8. Gregg Loewen
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
