What to buy?????
Discussion in 'Speakers' started by Shannon W, Aug 26, 2006.
  1. Shannon W
    Shannon W Stunt Coordinator
    Oct 11, 2002
    199
    Ok Guys what do I do. I’m looking at adding some new equipment to my home theater. What I'm looking at is ether a new sub "SVS PB12-Plus/2" to replace my Velodyne CHT-12. Or do I keep my Velodyne sub and ad the velodyne SMS-1? Which one would I see the best bang for the $$$$. Thanks Shannon
  2. timZa
    timZa Stunt Coordinator
    Jun 1, 2006
    95
    Hi Shannon,
    I was running a CHT12 and bought another CHT12 off Ebay. running the 2 i still was not satisfied. the CHT was good in a smaller room but i moved and my family room sizer is double what it use to be. it is a 4000cft room with ceramic tile floor. as SVS advice i bought a PB12+2. i have not hooked it up yet because I'm waiting on new speakers. so if you have a big room you may want to really consider the SVS. email them and give them size of your room and your listening style and see what they recommend. IMO the best buy for the $$ is SVS. like i said i have not ran it yet, but the the specs are better then just about anything in the price range. i hope this helps good luck!
