What Subwoofer would you pick out of these ?
Discussion in 'Archived Threads 2001-2004' started by BryanJ, Sep 4, 2001.
  1. BryanJ
    BryanJ Auditioning
    Aug 26, 2001
    13
    Subwoofer will be used for mainly home theater DVD's, what would you pick ?
    Klipsch KSW-12
    JBL PB-12
    Sony SA-WM40
    Paradigm PDR-12
    What would you pick
  2. Jin E
    Jin E Second Unit
    Nov 19, 2000
    452
    I agree with Sean's post... both of them!
    -Jin
    My Theater
  3. BryanJ
    BryanJ Auditioning
    Aug 26, 2001
    13
    So the JBL PB-12 is the one ?
    Ok, does it go loud ? can it go down to 20hz ? does it have clean tight bass ? is it powerfull can you feel it ?
  4. Scott Simonian
    Scott Simonian Screenwriter
    Jun 20, 2001
    1,281
    I conquer with you all. My friend just recently got the PB-12 and its pretty decent.
    Its pretty articulate for its low low price. Still has the SLAM on movies all the way!
    Go with it man! [​IMG]
    Yes, these are bruises from fighting. Yes, I am comfortable with that. I am enlightened.
  5. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
  6. Vin
    Vin Supporting Actor
    Oct 23, 2000
    546
    I haven't heard the Paradigm but have heard the others on your list. FWIW, of those three my choice would be the PB-12. I suggest that you audition each one yourself if possible, if you haven't already done so.
    Vin
  7. Ron Reda
    Ron Reda Cinematographer
    Jul 27, 2001
    2,276
    2
    110
    Again, based on price/value, I don't think you can beat the PB12.
  8. John B. Holbrook
    Dec 21, 2000
    44
    I just wanted to give a "shout out" to the KSW-12, which I own. At 440 Watts, it's plenty loud and I don't think you'll get noticably better performance until you step up to the SVS arena. And, it can be had for under $300.00. Do audition it if you get the chance!
    John Holbrook
    MY DVD Collection
  9. anthony_b
    anthony_b Screenwriter
    Aug 18, 2000
    1,077
    4
    110
    Check out the velo ct 100 at onecall.com $299. I have one and I almost freaked out with u571 dts and ID4 DD.
  10. Vin
    Oct 23, 2000
    546
  11. ToddJoseph
    ToddJoseph Stunt Coordinator
    Sep 9, 2000
    66
    Bryan,
    I was in your same shoes about 8 months ago and I decided to save a little longer and pick up an SVS. Your sub is one of the most important pieces in your HT equipment. Don't settle for less. A SVS 20-31 should fit your needs quite nicely
  12. Jin E
    Jin E Second Unit
    Nov 19, 2000
    452
    Also don't count ou the Adire Audio Rava for $399 (and it's powered unlike the SVS). Again another great bang for the buck sub.
    -Jin
    My Theater
