What sub do I buy. Final piece to the puzzle!!!
Discussion in 'Archived Threads 2001-2004' started by Edi, Sep 9, 2002.
  1. Edi
    Edi Extra
    Aug 22, 2002
    16
    I have a 3802 Denon, with Paradigm Reference. 60's up front, 20 in the rear, and a CC. The room size is 17x25, but the speakers are set up 17x17. I have 8 ft. ceilings, real wood on the walls, and rug that's with padding.
    So, what would be a good sub, a great sub, and the absolute best sub on the market for my set up.
    thanks in advance ed
  2. Rob Rodier
    Rob Rodier Supporting Actor
    Jul 11, 2002
    538
    I'll beat all of SVS reccomendations with one for M&K. I beleive they are the best sounding subs for the money. unless you have 3k to drop on a Revel, M&Ks are the way to go. Preowned models are not too tough to find either.
    -rob
  3. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Fairly off topic, but in a room that size, I think you will find you be pushing the limits of power for the Stuido 60s with that receiver at louder levels. You might want to consider external amplification for the mains.
    What price range for the sub? Movies or music?
  4. ReneA
    ReneA Agent
    Dec 17, 2000
    34
    Have you considered the HSU VTF-2 or VTF-3? The VTF-2 goes for around $450 and the VTF-3 goes for around $800.00. Plenty of power. Fondly mentioned in rewiews.
  5. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    I punched in your room dimensions in my room mode calc. The biggest problem may lie at 66-67hz with your sub in the corner. The first order resonances are 22, 33, and 70hz. These are frequencies where the room could suck out the bass from the middle listening area.
    It could get pretty costly if you want deep bass throughout the room. Have you considered DIY subwoofers?
    $350 can get you a Parts Express Titanic
    $400 can get you an adire rava
    $400 can get you a DIY adire 250 watt tempest.
    $550+ can get you a powered SVS
    $850 can get you a HSU VTF-3
    $2899 M&K MX-5000 THX MK II
    $3500 can get you a Velodyne servo HGS-18
    $4000 can get you dual JBL HTPS-400 (2,000 watts of THX bass)
    $5000 can get you SVS SS
    $22,000 can get you Wilson Audio XS (112db+ @ 16hz)
    $28,000 for a Krell Master Reference (120db+ @ 20hz)
  6. MarcVH
    MarcVH Second Unit
    Dec 26, 2001
    324
    I have pretty much the same setup as the original poster, but I have cheaper surrounds and a smaller room.
    Re the 3802 not providing enough power for the Studio/60s, if you run them as "small" once you get your sub that should reduce the risks there.
    For what it's worth, I ended up choosing SVS for subs, dual 20-39 CS+ tubes. It's a bit more than was probably necessary but I'm not regretting it a bit.
  7. Rob Rodier
    Jul 11, 2002
    538
  8. Edi
    Edi Extra
    Aug 22, 2002
    16
    I am trying to stay in the "reasonable" price range, south of 600.00? Does that make sense? Mostly movies, although this is the entertainment area, so music will be played 30% or so. I am a much bigger movie fan.
    Model numbers and names would be greatly appreciated. Still a newbie!
  9. Adam Horak
    Adam Horak Stunt Coordinator
    Jul 3, 2002
    123
    If you want to stay under $600 I would recommend a 20-39 PCi from SVS. I own it myself. I've not heard it with the Paradigms but many have expressed the opion that it blends quite well with them.
  10. MarcVH
    MarcVH Second Unit
    Dec 26, 2001
    324
    Whether a $600 price range makes sense is entirely a function of you and what you enjoy about movies; just recognize that this means a sub which is a probably a tier below the rest of your equipment.
  11. Ben_wood
    Ben_wood Stunt Coordinator
    Jun 21, 2002
    234
    A pair of Hsu VTF-2s or a single VTF-3 would rock your world. [​IMG]
  12. Michael R Price
    Michael R Price Screenwriter
    Jul 22, 2001
    1,591
    Edi, please visit this page:
    http://www.acoustic-visions.com/performancekits.htm
    The "Vented 214 liter kit" listed at the bottom is somewhere between the performance of a SVS CS+ and CS-Ultra (especially if you substitute 4" ports for the 3" ports shown), and ahead of most of the other models mentioned above. Of course, you could build such a sub yourself for a lower price than is shown on that page (around $400 as Chris stated). More information about this kind of product in general can be found in the DIY forum.
  13. Edi
    Edi Extra
    Aug 22, 2002
    16
    Well,
    ordered the 20-39 PCi from SVS. I will let you know how it goes. Thanks for the input. ed
  14. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    Thanks for the order Ed, We'll most likely be shipping it out in about 12 hours...so be sure to let me know if you have any setup/calibration questions while you wait for it to be delivered.
    TV
  15. ReneA
    ReneA Agent
    Dec 17, 2000
    34
    Right On, Ben_wood!!!
