What spear wire should I use for rear surrounds
Discussion in 'Archived Threads 2001-2004' started by Rodon, Jul 31, 2002.
  1. Rodon
    Rodon Second Unit
    Jul 4, 2002
    290
    I will be installing two new rear surrounds. I need about a 60' run of wire to them. Any suggestions on what I should use to run a cable length of that long?? Any recommendations and or suggestions on where to buy the wire cheaper than Best Buy [​IMG]
    May be running it under a crawl space as well so should I get wire that meets US building codes?
  2. Bruce Chang
    Bruce Chang Second Unit
    May 10, 2002
    283
    Radio shack flat wire 15awg.
    Partsexpress.com sound king speaker wires.
    You don't need anything fancy for the rears.
  3. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    you want to meet code. don't screw around with potential insurance issues. partsexpress is a good place, for example
    12 gauge 100ft for 21.50.
    14 gauge 100 ft for 24.80
    Although I generally prefer 12 gauge as an all purpose solution, i like the 2nd choice above better as it has a higher strand count of copper, making it more flexible and easier to work with.
    You might want to consider giving them a call and see if they have any high strand count 12 gauge.
    Inexpensive either way I think.
  4. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    Go to Home Depot. They have all sizes and types that meet code. They can cut to length also.
    I would use at least 14 AWG. 12 AWG is even better.
  5. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    I second using 12 guage for the surrounds.
  6. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    For longer runs you'll want thicker gauge (less loss). Get some 12 gauge wire from Home Depot (rated for conduit use).
