What size SVS?
Discussion in 'Archived Threads 2001-2004' started by WilliamJay, Mar 16, 2002.
  1. WilliamJay
    WilliamJay Stunt Coordinator
    Nov 16, 2001
    52
    My living room is 9x11x19 and opens up to the dining room. I do not listen to music or movies very loud but I do want to hear all the effects when watching HT. I am probably 50/50 as far as HT/Music.
    Appreciate any input.
  2. Jeffrey Forner
    Jeffrey Forner Screenwriter
    Jun 19, 1999
    1,117
    Get a 16-46 series sub. It can be a CS, PCi, or a CS+, I don't care. It's great for music and will certain kick your butt when it comes to movie soundtracks.
  3. WilliamJay
    Nov 16, 2001
    52
    bump
  4. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    I second J-Fo's rec.
    But, if you can afford the 16+, get that.
    Since your room is large-ish AND is open to another, get the plus.
    Or the 16-PCi will be fine, if you don't want the amp in the equation...
    Any questions?
  5. WilliamJay
    Nov 16, 2001
    52
    I would really appreciate any ideas
  6. Greg Br
    Greg Br Second Unit
    Dec 13, 2001
    437
    since you do not intend on really cranking it up I would think you could use any SVS sub to satisfy you needs, obviously if you want lows down to 16hz then you may want the 16-46, but I think any of lines of subs will work.
  7. Trent C
    Trent C Agent
    Dec 3, 2001
    38
    William,
    Have you dropped the guys over at SVS an email yet? They are very helpful. I dropped Tom a quick diagram of my room with dimensions and the layout of stuff. He got back to me right away and helped me choose. The email address is [email protected]
