What size speaker needed for 3 car garage? (1 Viewer)
darlene
darlene bishop
My husband and I have a 3 car garage (mancave). We recently purchased a hot tub and now can't hear the TV while we relax in it. We purchased a 200W sound bar but it doesn't get any louder than the speaker built into the TV. What kind of speaker or sound system do we need? The TV is about 15 feet from the hot tub. We would prefer something wireless and with Bluetooth. I have tried to google information but the more I read about Watts, dBs, OHMs, IEC, the more confused and frustrated I get. I have no idea what any of that means. HELP!!!!
JohnRice
Bounded In a Nutshell
A Mile High
It doesn't need to be wireless or have bluetooth, it just needs to be decent quality, which it sounds like the soundbar you got isn't. What soundbar did you get?
Robert_J
Mississippi
What do you mean by "wireless"? A wireless connection between the TV and speaker?
Since you have a hot tub in an enclosed (or sometimes enclosed since your garage door probably works), the humidity will be higher than normal. Therefore I suggest a speaker from the pro audio field. The https://www.amazon.com/dp/B00MX3OO1S?psc=1 LyxPro SPA 8 has a plastic cabinet and is designed for a more rugged environment. You need to connect each speaker to your TV via RCA cables. You can also play music via Bluetooth from your phone.
Since each speaker has its own built-in amp, there is no other equipment required.
darlene
darlene bishop
Yes, wireless from the TV to the speakers would be preferred. Thanks for the advice. We are considering a multi speaker theater system. But again, so many options are available. And I think the associate at Best Buy knew even less than I did.
Latest posts
MusicLover95
